Assign priority1 and priority2 values for a PTP clock instance.
boundary |
Boundary clock instance. |
ordinary |
Ordinary clock instance. |
priority1 |
Priority1 of the clock. |
priority2 |
Priority2 of the clock. |
priority |
Value of priority. 0 is the highest priority. The default value is 128, the range is 0-255. |
The default value of the priority is 128. The range is 0-255.
Use this command to assign priority1 and priority2 values for a PTP clock instance. This command is available only for boundary and ordinary clocks.
The following example assigns priority1 and priority2 values for the boundary clock:
# configure network-clock ptp boundary priority1 50 # configure network-clock ptp boundary priority2 128
The following example assigns priority1 and priority2 values for ordinary clock:
# configure network-clock ptp ordinary priority1 10 # configure network-clock ptp ordinary priority2 200
This command was first available in ExtremeXOS 15.1.
This command is available on the ExtremeSwitching 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
